Tool Talk Discussion Forum
damper
504-2
11-27-2007 16:59:02
I need a place to buy a Thermal damper 6in.
T_Bone
11-29-2007 16:21:14
 Re: damper in reply to 504-2, 11-27-2007 16:59:02
Hi 504-2,
As Dusty was saying you need a UL approved powered exhaust vent for your tankless heater, read as a OEM part. If you don't have a UL listed part then your probably going to fight with your insurrance company when the time comes.
Alot of the OEM vent kits have a provision for make up air as it exhausts the waste gass.
Venting by internet will surely get someone killed! Exhausting by-products of combustion is a very complicated subject that takes books written on the subject to fully understand the codes and concepts. That's why I suggested a OEM vent kit as all the above has been well thought out in advance for you.
T_Bone
Dusty MI
11-29-2007 15:46:22
It sounds like you need more fresh/make up air in your home. Many home today are too tight.
If you have a forced air furnace bring a 5 or 6" round duct from out doors into a return air duct. Then add a grill to the return near the furnace, for combustion air.
504-2
11-28-2007 19:15:57
Dusty, My tankless water will back draft and freeze. This house is so tight that when the furnace comes on it back drafts. We added some fresh air to the system but I hate heating outside air. This is what happens when one contractor does the heating and I spec ed a tankless heater. 6in double wall gas flue
Dusty MI
11-28-2007 06:34:15
Need more details, open or close on temp. rise, at what temp. Or a fire damper.
Dusty
