rear axle seal tool
kano
11-28-2007 20:54:54
Greeting to all,
Trying to install rear axle seals in mf 265. In the Philippines and find myself in a bind. Only tool to pull plantary from axle shaft is in manila(one Hour flight north)and not available. Can someone give a description,measurements,photo?so can manufacture same here at machine shop? Know Odds are bad but can only ask. Thank you in advance for any input. Suggestions welcome.
Have a great day.
Joe
(Malaika_41@yahoo.com)
kano
12-01-2007 02:05:29
 Re: rear axle seal tool in reply to Keith in ME, 11-28-2007 20:54:54
Thank you for your response. Gives me a direction and This was what I was looking for. Nice to see a can do attitude.
Joe
imlll
11-30-2007 07:54:05
 Re: rear axle seal tool in reply to kano, 11-28-2007 20:54:54
I don't know if it is comparable, but I made a device to separate the outer axle stub from the planetary carrier on my MF Super 90. I purchased a piece of steel 1" thk. x 12" sq and drilled holes to match the carrier. I used (3) stud bolts, with nuts, I believe they were 1 1/4" dia and used a 50 ton hydraulic cylinder. To make this all manageable, I drilled and tapped a 1/2" hole into the center of the plate and installed an eye bolt, then suspended all from an engine hoist.
Charles (in GA)
11-29-2007 17:44:57
Be sure and post this on the YT Mag Massey forum also, as someone may have the tool they can send you pics and measurements of.
Charles
Kano
11-29-2007 21:44:41
 Re: rear axle seal tool in reply to Charles (in GA), 11-29-2007 17:44:57
Charles,Thank you.will do.
Joe.
