You mention "A huge difference between the quality inverters and the cheaper ones is the efficientcy (lower) and idle current draw (higher)." Very often, that is NOT the case. Most of the high-end full wave inverters are less efficient that the cheaper modified wave inverters. Sometimes less by 5%. Go read the specs on Xantrex/Trace or Outback. I've got several models from both companies and researched it well before buying. My house runs off of stacked Outback full-wave inverters. My cabin runs off of stacked Trace/Xantrax mod-wave inverters. I would of prefered modified wave Trace inverters for my house, but they won't qualify for selling back power to the electric company. In regard to idle, or stand-by current draw, with most newer units, regardless of price, there's very little difference - except one thing. Some of the better built units, mod-wave or full-wave are load sensing, and can sit in stand-by mode with very little current draw until they sense demand. Also, that demand-sensing is adjustable. In regard to mod-wave inverters, price and quality. I've got several Trace/Xantrex 2400 watt units (inverter/charger) that cost close to $1000 each. I also have some Chinese Harbor Freight 4000 watt inverters that cost $129 each. The cheap Harbor Freight inverters make power every bit as good as the high-end Trace inverters, and so far have help up very well. I've been using them to run high-draw power tools for two summmers while building a cabin in an off-grid area. I didn't expect much from them at first, but am now pretty amazed at their quality. In my opinion, they are better than some TripLites. I've got a 750 watt (1000 surge) TripLite that I can't stand to use, mainly because the cooling fan runs all the time. My cheap HarborFreight inverters have dual thermal-controlled fans that only come on when hot. If you want to run a good test on a cheap mod-wave inverter - use it on a standard shop-style automotive battery charger. That will tell you a lot. Get a car battery that needs charging. Then hook your charger to it plugged into grid current and look at the rate of charge. Then, try it running off your inverter. Very often, if you get 30 amps while on the grid, you will get 20 amps from one brand MW inverter, and maybe as low as 10 amps from another. Interference is another test. Run a TV a couple a feet from the various inverters - with some the picture will be clear, and with others, it will get interference lines.
