Tool Talk Discussion Forum
Oil/Gas Mix
1945 A
01-10-2008 08:25:12
I've got several 2 cycle tools around the house, and, it seems that all require a different oil/gas ratio---from 40:1 to 16:1.
I was wondering what determines oil/gas mix ratio (besides the mfg.)? Is it engine tolerances?
I would like a universal blend for obvious reasons, but don't want to burn anything up for lack of oil, or live with power loss issues from too much oil.
Thoughts/ideas?
Thanks in advance!
TimV
01-11-2008 08:29:37
 Re: Oil/Gas Mix in reply to 1945 A, 01-10-2008 08:25:12
Buddy of mine runs 50:1 with Amzoil (sp?) in every 2-stroke he owns, and has for many years with no problems. His engines run the gamut from old outboards to brand-new Stihl chainsaws to dirt bikes and everything in between. This isn't intended as a recommendation, just an observation, and I personally keep on hand a 25:1 mix and a 50:1 mix with good-quality 2-stroke oil and err on the side of too much oil if there's an overlap--I can buy a lot of oil for the price of one engine rebuild. Also, some manufacturers will not honor your warranty if you do not use their oil--another friend found this out the hard way on a brand-new Ski-doo snowmobile. Apparently there are some brass or bronze parts in Ski-doo engines that will not receive proper lubrication unless you use an oil with special additives, and the Ski-doo dealer could tell immediately upon tear-down that he had not used Ski-doo oil (which was true, and he had not told the dealer this before tear-down), which voided the warranty. It's possible that he could have fought it, but he bit the bullet, re-built the engine himself out-of-pocket, and has not had any more problems now that he uses Ski-doo oil.
dave guest
01-10-2008 18:54:13
I just kinda average it out. My uncle in fla. had boat motors he only used gasoline, said there is enough oil in the gas anyway. If he learned otherwise, he never admitted it.
Dan (wi)
01-10-2008 18:15:30
I too had several small gas cans with several diff mixes of gas / oil.Sold all the gas cans & now use Opti in everything,less smoke better starting. I have even talked many of my freinds into doing the same thing with no complaints.
buickanddeere
01-10-2008 18:06:58
Some manufactures of two-stroke oil sell different versions for high HP/lb aircooled chainsaw engines v.s a water cooled outboard. Adding more oil ,lowers the octane rating of the fuel. On a borderline engine running plenty hot/lean or on low octane fuel. It can be enough to push the engine into detonation. Not every scored cylinder wall, broken ring, cracked or burned piston was the result of lubrication failure.
JT
01-10-2008 18:37:17
 Re: Oil/Gas Mix in reply to buickanddeere, 01-10-2008 18:06:58
Very well said!!!!! They also make differant oils for differant RPMs. ie, Lawn Boy oil is designed to run at 3600 RPM, whereas Opti oil, Stihl, Echo, Dolmar, etc, high quality, oil is designed to run at over 15,000 RPMs.
Jim
jdemaris
01-11-2008 08:09:57
 Re: Oil/Gas Mix in reply to JT, 01-10-2008 18:37:17
Many companies with high-speed air-cooled two-stroke-cycle engines have allowed conventional motor oil to used - as well as the high-end stuff - just with different mix-ratios. This ended with EPA regs calling for less pollution.
For example - Stihl states: 1:25 ratio when using SAE engine oil, and 1:40 to 1:50 when using Stihl two-cycle engine oil.
Generally speaking, I doubt you're going to find a verified example of anyone having an engine problem because they used a TCW (water-cooled rated) oil in a chain saw, or a heavier ratio mix of any oil.
The simple fact is - getting the API two-stroke TC rating is expensive and most oil companies don't bother. That's doesn't mean they don't meet the specs - they are just not spending the money to prove it. To the converse, the TCW rating is needed for many warranties in the boat industry - so for that market - the extra money is spent for certification.
I started working as a saw mechanic back in the 60s. I think I've seen just about every type of failure there is - within that market. I've also cut a lot of wood over the years and use many types of two-stroke-cycle saws and other type of equipment. Many older - especially consumer-level saws used to have very poor cylinder walls. Some just aluminum, some with a thin and poorly bonded chrome plating, and a few with real iron liners. Stihl got famous with their Mahle process. What ever exactly is was - or is - it worked. A saw with a good cylinder wall and real ball-bearing mains (no sleeves or needles) can last virtually forever if cared for. These attributes were common in the 50s, then pretty much disappear later in consumer saws, and now - they're back again to some degree.
Most saws I've seen destroyed - got that way from lugging them with dull chains - or running too lean due to various reasons. Lean with a 16 - 1 one mix is one thing, and lean with a 50 - 1 mix is another. Besides the overheating issue from a lean air-fuel ratio in itself - you also get the additional lack-of-lube problem from it.
I've never burnt up a cylinder wall or piston - ever - in any two-stroke-cycle engine and I use cheap oil and a heavy mix. I'm still running a few old Remington Mall saws, some 50s Homelites, a Hoe, many Stihls from the 1960s, and well as some newer stuff. I've had zero prolems with cylinder walls, crank bearings, port plugging, etc. Subsequently - I don't think the expensive oils amount to any measurable gain - unless you insist on running lean and/or abuse your equipment.
buickanddeere
01-12-2008 09:42:33
 Re: Oil/Gas Mix in reply to jdemaris, 01-11-2008 08:09:57
Quote" Most saws I've seen destroyed - got that way from lugging them with dull chains " Unquote You "hit the nail on the head" with that statement.
jdemaris
01-10-2008 15:59:56
I've been using 16 to 1 in everything for 40 years and had no problems. Small engines with tiny exhaust ports or spark-screens will plug up once in awhile (like weed eaters) - but otherwise, all is fine.
I've got many two-stroke-cycle engines on portable water-pumps that I use in maple sugaring. And, many chain saws from the 1950s to present. Years back - many cheaper saws needed 16 to 1 because of a poor cylinder wall design and main-bearing design. The better saws - like Stilh, Sachs-Dolmar, Husky, Jonsered, etc. had much more durable wall-liners and could stand 40-1 or 50-1 with the better TCW rated oils. Now - with all the EPA regs - even the cheap saws have to put in more durable liners in to be able to run on 50-1. The older cheap saws would burn up pretty fast. That being said, any saw will last longer with more oil in the mix.
The oil has changed too -considering in the 1960s - SAE 30 W motor oil was recommened. The later outboard-certified TCW oil has better protection.
neblinc
01-10-2008 13:04:58
My dealer recommended this stuff.
Link
Been using it for about 5 years with no problems.
Randy
Steve A W
01-10-2008 10:42:08
I have used Opti 2 for 20 years or so in everything from old Yahmaha dirt bike, Lawn boy
mowers, Toro snow blowers, to any bunch of weed
wackers,& small engines, and have never fouled a
plug or plugged an exhaust.
It's some really good mix.
Stumpalump
01-10-2008 10:00:41
I notice on Lawn Boy lawn mowers that the recomended amount of oil has got less and less thru the years. If you look up the part number for a long block it has stayed the same. Hmmm. I asked and was told that the EPA made them reduce the amount of oil but the oil itself got a little better. I run as much oil as I can without plug fouling or ruff running problems.
Eldo case
01-10-2008 09:42:49
This what I use in all of my stuff Link
Never>Link a problem for years now!!!!!
( sonny )
01-10-2008 09:33:51
40:1 equal how much oil to how much gas?
16:1 equal how much oil to how much gas?
what type/kind of oil is used?
thanks sonny
JT
01-10-2008 14:30:20
 Re: Oil/Gas Mix in reply to ( sonny ), 01-10-2008 09:33:51
50:1 is 2.6 oz oil per gallon of gas
40:1 is 3.2 oz. oil per gallon of gas
32:1 is 4 oz oil per gallon of gas
16:1 is 8 oz oil per gallon of gas
to find out how much oil you need take 128 divide by the mixture ratio number, that will tell you how much oil to put in a gallon of gas. ie
128 divided by 40 is 3.2
El Toro
01-10-2008 13:07:18
The 16:1 ratio is 8oz of oil to one gallon of gas.
If it's 32:1 ratio you would use 4 oz of oil to a gallon of gas. Use 3.2oz of oil for 40:1 ratio in one gallon of gas. Hal
PS: I use 30wt engine oil.
Bob - MI
01-10-2008 09:23:38
Lots of times it has to do with the type of bearings that they are using.
High oil/fuel (16:1) requirements can be driven by the engine having plain bearings. Low oil/fuel (40~50:1) would suggest to me that there are likely ball and/or needle bearings.
JT
01-10-2008 13:56:33
 Re: Oil/Gas Mix in reply to Bob - MI, 01-10-2008 09:23:38
The older stuff requiring a lot more oil had a straight aluminum, no alloy cylinder, needed a lot of oil to keep it lubed, the newer engine use a harder alloy steel in the cylinder, so they require a lot less oil. A lot of the cheap saws still use poured bearings/bushings and no needle bearings.
Jim
