Air Compressor HP Ratings
TWJanak
01-15-2008 16:28:19
Why can I buy a 15 CFM @ 175 psi compressor with a 5 HP electric motor, but with a gas engine the engine HP is 10-12?
I have a 5 HP compressor (just the pump) that is rated around 17 CFM at 175 psi. The literature says its a 5 HP pump. I assume a 5 HP electric motor would run it, but I doubt a 5 HP gas engine would do as good.
That said, I'm going to try the 5 HP gas engine anyways on my pump, it's all I have. I'll just regulate down to 110 psi or so.
TWJanak
01-16-2008 07:07:32
 Re: Air Compressor HP Ratings in reply to TWJanak, 01-15-2008 16:28:19
It will have an unloader when it hits the cutout pressure (110 psi). During pumping, the engine will run at max HP (3600 rpm) and after cutout, idle down because the pump is unloaded.
That being said, I don't see why 5 HP gas engine at max HP (3600 rpm) is any different than than the electric motor. They should both be putting out rated HP. Obviously it is though, all the ones I see for sale have twice the HP if gas powered.
Bus Driver
01-16-2008 04:45:07
For gasoline engines, the HP rating is the maximum that the engine will develop. With electric motors, the HP rating is the continuous output, for the time rating of that motor. For short periods of time, electric motors can deliver at least twice their rated horsepower. Amperage draw increases sharply and the motor gets hot in such situations. But a compressor has a heavy load for part of a rotation/revolution and a light load for part of a rotation. Electric motors respond better and faster to varying loads. The short duration loading during a rotation/revolution of a compressor works well for electric motors.
IH2444
01-15-2008 23:12:52
Umm doesn't gas powered compressors need an unloader valve that is not required on electric compressor pumps ? something is needed to stop the pump from pumping once pressure is reached.
an electric motor one starts and stops, but the gas engine keeps on running.
KEB1
01-15-2008 19:21:22
The difference has very little to do with running horsepower (horsepower is horsepower) and everything to do with starting torque. A capacitor start electric motor generates maximum torque at or near stall, a gas engine generates no torque at stall and not much at low speeds. A larger gas engine is required to provide sufficient torque to start the compressor without stalling, not to keep it running once it has started.
I'll bet the gas engine is running on part throttle (and therefore not putting out its full rating) except when it has to start the compressor. Its probably also running a lot slower than the speed at which it produces the rated horsepower. Contrast this to an electric motor which runs at a (more or less, anyway) constant speed regardless of load.
Keith
markiz41
01-15-2008 18:20:08
5hp gas is about 2.5hp electric. It will run your pump, you'll just have to slow it down some by putting a smaller pulley on the engine. Regulating the cutoff pressure down like you said is also a good idea. You won't get 15 cf, though, maybe 10 or 11 at 110 psi.
JMS/MN
01-15-2008 18:12:14
Normally a 1 to 3 ratio comparing electric motor to gas engine. And that motor labeled 5 HP in the advertising is probably about 4hp. Check the motor nameplate for amperage draw. Watts equals Amps times Voltage. 745 watts equals 1 hp.
