I just read all the posts for the outdoor boiler sounds interesting , but cutting and handling wood creates a lot of heat on its own. Has anyone looked into heating with corn, wheat or rye? The past 2 winters I have used corn, wheat or rye to heat my shop (40X56) and my old farm house. I am using some old Dovetec corn stoves I picked up at an auction. The stove in the house is putting out about 24000BTU to 30,000BTU /hour and does about 60% of my heat load on the coldest days. My neighbour (a farmer and Mechanical enginneer) and I have modified the units to run under vacuum and installed homeade plate heat exchangers to increase the stoves eff. to around 96%. The exhaust is comming out well under 100 degrees F.The exhaust used from the back of the exchanger is PVC pipe. No smoke or smell when the door is open and I can run waste grain to heat. I have a seed company that gives me old stock and other farmer give me the tail end of old bags or treated seed. The grain stoves are great no wood to split, stack, cut haul.There is no ash or smoke either just a CLINKER to remove once a day (and its fertilizer).I put the grain in small gravity box wagons for storage and moved it to the house/shop in pails. 1 load per week about 9 bushels. This year I plan on making a vacuum delivery system, to draw the grain into a small storage tank. No more pails.
