Bruce Hopf
04-14-2008 19:48:18
Re: Advice on buying a welder in reply to 300 Mag, 04-14-2008 19:07:17
If you can afford it, I would go with an AC/DC Stick welder. My first welder was strictly AC stick, something that I could afford at the time. I had it a few years, for light welding, off the farm. But when I moved back onto the family farm, I experienced that the AC welder was too light to do some of the heavier type repair work, that needed different position welding. It was a constant struggle to try different position welding. Since then I purchased Purchased a Lincoln AC/DC stick welder, about 4 years ago. I have no problem welding any position welding with this machine. For lighter work, and flat welding, I use AC. For the heavier welding, and other position welding, I use the DC. Wire welders, with gas is for medium welding, is OK for some jobs. I bought a Lincoln Wire welder with gas 2 years ago. Its real nice to work with, fort light to medium welding, and for most jobs. But some of the work you require a heavier welder, that's where your stick welder comes into play, especially with a DC welder. You can really turn up the heat, for good penetration with a DC welder. You also can turn up the heat with a AC welder for doing some cutting, if you don't have a cutting torch. If it was me, being having both, I'd get the AC/DC welder before a wire feed, because of its varsity. My opinion any way. Bruce.
