Extremely Deep Well Socket
Pooh Bear
04-16-2008 20:30:02
My brother needed an extra deep socket.
Don't know how the nut was put on there but it couldn't be gotten
to with a wrench, and a socket with extension wouldn't work either.
He brought me a regular socket, a length of water pipe and a wrench.
He asked me if I could weld it all together. I said maybe.
I did suggest he substitute a bolt for the wrench.
He could use a ratchet on the bolt and save the wrench.
The socket was a cheap throw away so no loss there.
My welds aren't pretty but this is the result.
third party image
Pooh Bear
Burnie
04-20-2008 03:48:38
 Re: Extremely Deep Well Socket in reply to Pooh Bear, 04-16-2008 20:30:02
I made one years ago the same way as Sam to undo spindle nuts on cotton pickers. Still have it somewhere.
Sam from WA
04-17-2008 14:54:14
I"ve got one or two extended deep sockets for taking the clamp on duals off Deere tractors. Only difference is the sockets I made I used an impact socket that i had several of and cut in half, welded some water pipe to the hex part and then welded the 1/2in square ratchet half to the other end of the water pipe. Makes short work of those real long clamp bolts.
FixaLinc
04-17-2008 13:51:30
Like said supply places for tire repair have ready made deep sockets for the snap on dual bolts. I've made some deep ones before too but usually cut the socket and put the square drive on other end of pipe or use a saved bad stripped out socket. Racheting end wrenches work in odd places too on long bolts.
hd6gtom
04-17-2008 12:03:01
Those are available at most farm tire shops. We used them to install dual wheels on tractors. Had them in 7 or 8 different sizes. We loaned them out all the time.
TimV
04-17-2008 07:53:04
Made one for a buddy who used it to take off the bolts holding the screens together at the gravel pit where he worked--took an all-day job down to a couple hours versus taking them off with end wrenches. Also made one for the axle nuts on the old Honda 3-wheelers.
kito169
04-17-2008 06:57:20
Having turned wrenches for 4 decades, I have said that you can tell how good the mechanic is by how many homemade tools are in his box. I don't see that many "techs" with this type stuff. No offense intended, young folks are techs. Us old farts are mechanics. Rick
Butch(OH)
04-17-2008 06:44:30
Me thinks that anyone who doesnt have a few of those around the shop hasn"t realy done much, LOL. Also makes me wonder about those who say there is NO uses for china sockets. My mechanic at work has a whole box full of extended sockets.
Kentb of SWMO
04-17-2008 05:51:31
I did almost the same thing. On a Gleaner C-II there is a 2 inch nut on the threasher clutch side of the main shaft. For the 2 inch socket I made a female hex from a "bisket" of shafting with my mill and deviding head.
Kent
jose bagge
04-17-2008 04:42:21
been there before! i love to see guys home-made tools! Torch and a welder is all a man needs- he can make everything else from there!
Bud in WV
04-17-2008 04:31:35
I've had to make some like that, too. A weld engineer I used to work with pointed out that 308 SS rod makes the tool steel of the socket more compatible with A106 type steel of the pipe.
rockyhawaii
04-17-2008 00:29:25
That's what Chinese sockets are for!
41JDb
04-16-2008 22:47:54
We made the exact same thing when we were erecting I beams and needed something to quickly put nuts on the beam pad studs. Looks good.
Davis SC
04-16-2008 20:46:53
I have a few home-made tools like that, sitting in the bottom drawers of my toolboxes.. Welding up things like that, I like to find a China socket, no use to ruin a good Proto, or Wright Socket..
