Tool Talk Discussion Forum
toro weed eater wont start when hot
Cameronzf
05-13-2008 14:55:55
Ive a toro weedeater thatll start when cold but if you stop it wont start when hot. what could be the problem?
El Toro
05-14-2008 18:14:24
 Re: toro weed eater wont start when hot in reply to Cameronzf, 05-13-2008 14:55:55
It could be the coil or ignition module. Check for fire to the sparkplug asap when it quits running. Hal
Jiles
05-14-2008 10:10:31
All small twocycle engines have a small poundage of pressure in the crankcase. Check that all screws are tight and there is no leaking seal.
Vern-MI
05-14-2008 04:24:33
Make sure the carb is bolted on tight and if it is then the coil is shot and / or the plug is toast.
oliver28472
05-14-2008 07:30:01
 Re: toro weed eater wont start when hot in reply to Vern-MI, 05-14-2008 04:24:33
Look for a spark arrest screen in the muffler. It may be clogged. I usually throw that away.
Duke(WNY)
05-13-2008 17:13:15
Try taking the gas cap off and then putting it back on - if the gas cap vent is not working right there will be a vacuum in the tank that will not allow the fuel pump to draw any gas.
Gumption
05-13-2008 15:17:38
It could be flooding, starving for gas, ignition related, or just so worn out that it won't make compression or crankcase pulsations needed to run.
Do the diagnostics.
Pull the plug when it's dead. Spark? wet? dry?
