Tool Talk Discussion Forum
echo trimmer not running well
300Randy
05-19-2008 13:59:01
I have an older echo trimmer thats not running good anymore. It will start good but will only run with the lever pulled just a little off from the cold start setting. If I push to the run position it just dies. Do I have a problem inside the carb or a fuel problem?
greygoat
05-20-2008 06:14:30
 Re: echo trimmer not running well in reply to 300Randy, 05-19-2008 13:59:01
My Echo string trimmer was new in 1984, now
giving lots of trouble, won't run good, when I
take it apart theres black goo in the carb.
I think it's from eythenal in the gas. I
retired it,Old dealer retired, got young punks
working there now, too many ear and nose rings
for me, so I went to an old Steil dealer, got new
trimmer, very pleased with it.
RobMD
05-19-2008 18:37:32
Spark arrester on the muffler anywhere? looks like a screen? Remove it.
IH2444
05-19-2008 14:39:05
Sounds like a new diaphram may be needed in the carb or possible a crack in the fuel line. Seems to be running lean for some reason.
If the trimmer is good otherwiast it is well worth having the carb rebuilt and the fuel lines replaced.
Echo are pretty sturdy machines, but the rubber parts in the carb and lines age from the fuel.
