3M Scotch-Brite Wheels
Dum Ole Bob
10-02-2001 08:32:43
Awhile back I posted a question about 3M Scotch-Brite Wheels in particular their EXL Deburring wheels. Among other things they are intended to replace wire wheels & eliminate “flying wires”.
Ok, I got a 6”, fine EXL wheel & I’m using it on a bench grinder. I use it for “polishing” mild steel after it has been sand blasted. IT IS SUPER! Although expensive, it produces a finish that is exactly what I’m looking for. Trouble is a 6” wheel on a bench can’t get in all the nooks & crannies.
I’d like to go one step further & use such a wheel on a 4” or 4.5” angle grinder & maybe a die grinder. Trouble is 3M makes so many Scotch-Brite wheels I can’t decipher all the info. I also live in Wyoming and can’t visit any outlets that know about this stuff.
Anyone with any experience in this area or with a telephone # of someone who is will sure be appreciated.
Rod MI
10-02-2001 23:05:11
 Re: 3M Scotch-Brite Wheels in reply to Dum Ole Bob, 10-02-2001 08:32:43
Good Ole Bob I'm currently looking at a 3M Scotch-Brite EXL Deburring wheel that you are looking for the size is 3 x 1/2 x 1/4 inch I think the part# is 8A CRS how I use it is cut of the head on a 1/4 inch bolt then put the bolt in your grinder then use the biggest washers you can find to support the weal then tighten up the nuts they throw junk all over the place and I highly recommend a grinder with rear exhaust if you don’t wont to go to the hospital with junk in you eyes any ways or use one of those face shields or both I now this is more then you knead but good luck and if you knead any more help just Email me or repost on this board good luck Rod MI
