2010 John Deere tractor
Bobby Dabbs
04-21-1999 08:23:12
I am having trouble with the clutch on this tractor. I can shift gears with the motor off. I can crank the tractor in gear and drive it around. I cannot clutch the tractor and idle.Does anyone have suggestions for unsticking the clutch. The tractor has set up for three years.
tom smallman
06-21-2001 20:43:22
 Re: 2010 John Deere tractor in reply to Bobby Dabbs, 04-21-1999 08:23:12
I would like to know if the rated engine hp is the same as the hp generated at the 540 rpm pto??
Can anyone help?
TVS
Rick
04-28-1999 19:35:08
Had the same problem with a JD crawler. The pilot bearing for the clutch was froze. Tried everything
including putting the tractor up against a tree and letting the tires dig. No luck. Had to split the tractor and redo the clutch. Good luck!!
