806D MCV Pump and lack of Power
George Smith
06-27-1999 12:19:43
After posting the last message about the lack of power that was intermitant we changed the MCV Pump on my 806D. Yesterday after this I pulled up to a pile of dirt and loaded it in the bucket in 2 low it had such power it churned both tires. Then turned around and put it in 2 high to move the dirt about 200 yards and it did fine in 2 high. Then I came back to the pile, put it in 2 low and loaded another bucket, again it churned the tires with great power, I put it in 2 high and it would basically not move, barely if it all. I am really baffled by this. Can the clutch do this? Could this be temperature related? Any help would be greatly appreciated.
George
RickB.
06-29-1999 15:44:57
 Re: 806D MCV Pump and lack of Power in reply to George Smith, 06-27-1999 12:19:43
You need to inspect the dump valve spool adjustment which is connected to the clutch linkage. You could also have a gasket or different spool problem in the multiple control valve itself. Did you disassemble, inspect & re-gasket the valve housing when you installed the new pump?
