7024 welding rod
CMB
09-10-1999 12:35:52
could somebody tell what 7024 rod is used for? Is it ac or dc, I purchased a used welder and there was a bunch of tis in the box Thank You
Gordon Dornick
09-10-1999 18:40:56
 Re: 7024 welding rod in reply to CMB, 09-10-1999 12:35:52
Hi, the 7024 rod is a 70,000 psi minimum tensile strength rod (The "70" indicates the 70,000 psi minimum tensile strength.) It is a rod intended for flat position and horizontal fillets. (The "2" in the third position indicates this.) It is used with AC or DC + or - polarity; and has a Rutile, iron powder (approx 50% iron) covering type. (The "24" - last two digits together indicate this.) This rod is sometimes referred to as a "production" type rod; it deposits a lot of weld metal (filler metal) fairly quickly, usually is recommended for clean metal with a reasonably good weld prep. and requires fairly high amperage to perform properly. Hope this helps, have fun, Gordon
cmb
09-11-1999 08:34:20
 Re: Re: 7024 welding rod in reply to Gordon Dornick, 09-10-1999 18:40:56
Thanks Gordon!
