79' cj5
robert
09-17-1999 21:37:11
OK i realize this is a little off the subject, but I have a question and I trust you won't steer me wrong. I just purchased a 1979 Jeep CJ5. It has 32'' tires on is as well as a 3'' lift. I would like to know if I can remove the lift kit and still use the 32'' tires.
Rob
05-14-2003 19:03:54
 Re: 79' cj5 in reply to robert, 09-17-1999 21:37:11
Hey my jeep has 31s on it and they clear good you should have room they might hit a bit once in a while but they should work.
Jennifer Bennett
06-05-2000 15:06:24
My boyfriend has a 1979 CJ5 and would like to purchase a hardtop for it. Any one who can assist me in this please email me.
Frogey
04-17-2000 05:49:28
Well robert if the tires are 32" and its got a 4" lift you can take the lift out.but,if you plan on putting a flexible suspention in the jeep well you might want to leave it.Another thing if you are going to be 4-wheeling with it you might also think of keeping the lift in it,you get more clearence ya know.well good luck,hope it works for ya. Frog-Man
Frogey
04-17-2000 05:49:08
BOB
02-23-2000 09:20:59
I HAD THE SAME SET UP. YOU SHOULDNT HAVE ANY PROBLEMS AS LONG AS THE SHOCKS STILL FIT, WHICH I DONT THINK THEY WILL. BE SURE THE WHEELS HAVE ENOUGH CLEARENCE FOR TIGHT TURNS AND BE SURE TO REPLACE THE SHOCKS WITH FAIRLY STIFF ONES TO MINIMIZE ROLL OVER. JUST OUT OF CURIOSITY WHY DO YOU WANT TO LOWER IT???
Chappy
09-18-1999 07:27:50
Robert:
You may want to get into a four wheel drive forum,
but tractor guys do know a little about other things too.
Without the lift kit the tires you have would probaly touch your body and may limit your turning ability. I have a set of 33" tires on my Jeep just
so I can roll it around while I do a restoration and no way could they work without a lift. My nephews Jeep has a 3" lift with a rancho suspension kit and he has no problems. For the past 15 years I have ran 10" x 15" Armstrong Tru-Tracs on my Jeep with good luck.
Chappy
