"Alumalloy"???
JerryU
06-06-1998 14:30:58
Just saw an infomercial on an aluminum rod used with a propane torch for aluminum and the like repair by the name of Alumalloy. It was kind of a low budget production, but if the stuff worked, it would sure be easier than having something heliarced. Anybody heard or used the stuff? At $45/pound becomes a bit pricey to try.
thanks
JerryU
duckman
08-21-1999 12:29:17
 Re: Alumalloy??? in reply to JerryU, 06-06-1998 14:30:58
: Just saw an infomercial on an aluminum rod used with a propane torch for aluminum and the like repair by the name of Alumalloy. It was kind of a low budget production, but if the stuff worked, it would sure be easier than having something heliarced. Anybody heard or used the stuff? At $45/pound becomes a bit pricey to try.
: thanks
: JerryU
Check out site : Link
travis stewart
12-18-2005 19:54:19
 Re: Re: Alumalloy??? in reply to duckman, 08-21-1999 12:29:17
I personally think the stuff is awesome, a real breakthrough if you ask me. it sure beats the heck out of JB-weld or paying tons of money to have something aluminum welded at a shop. 45 bucks a pound is kinda steep, but if it works as good as it needs to thats a miniscule drop in the bucket compared to welding fees.
the only thing I would be concerned about is it's ability to carbonize and be able to hold up to extremem heated environments. so far it looks to be useful for just about everything I personally would need it for, but you just have to take into consideration what the prupose is..... whatever you're gonna use it for just make sure that the repaired environment doesn't exceed 700 degrees and you should be in good shape. : )
Noreen
12-13-2005 08:48:38
I ordered some for my DH, and he loves the stuff!
jeff rienzi
10-03-1998 09:27:17
 Re: in reply to JerryU, 06-06-1998 14:30:58
:Just talked to the alumaloy company. you can reach thier web site at www.alumaloy.net or call the company @ 1800-917-9353
: jeff r
jeff rienzi
10-03-1998 09:26:50
:Just talked to the alumaloy company. you can reach thier web site at www.alumaly.net or call the company @ 1800-917-9353
: jeff r
jeff rienzi
10-03-1998 09:23:18
: thanks
: JerryU
raymond j. impastato
07-29-1998 19:10:38
 Re: "Alumalloy"??? in reply to JerryU, 06-06-1998 14:30:58
dear jerry u.
if you would like to get all the info on "alumalloy"
you can call toll free @ 1-800-917-WELD(9353)
and they will fax (not e-mail) a fact sheet. i spoke to an engineer on 7/29/98 and he said the only environment that is detrimental to the product is salt water. the repairs have to be sealed with epoxy primer or paint. clear epoxy paint works adequately according to him.
i am an engineer myself, and i do design for aluminum fabrication in a marine environment. if this product works as good as they claim, operators could do field repairs without ever returning to port.
good luck raymond impastato
farmer
06-06-1998 20:27:15
: thanks
: JerryU
I have seen a product like you describe at farm shows for several years. It demos real well, so I bought some (about a $1.00 per rod as I recall) . Sadly it has spent the last couple of years somewhere on one of the benches mentioned in the post below. You use a stainless steel brush to clean the surface first and I can't remember to buy one. I got to handle a bunch of their demo items and they felt like they would hold.
Good luck.
Steve
09-13-1999 05:41:39
 Re: Re: Alumalloy??? in reply to farmer, 06-06-1998 20:27:15
: : Just saw an infomercial on an aluminum rod used with a propane torch for aluminum and the like repair by the name of Alumalloy. It was kind of a low budget production, but if the stuff worked, it would sure be easier than having something heliarced. Anybody heard or used the stuff? At $45/pound becomes a bit pricey to try.
: : thanks
: : JerryU
: I have seen a product like you describe at farm shows for several years. It demos real well, so I bought some (about a $1.00 per rod as I recall) . Sadly it has spent the last couple of years somewhere on one of the benches mentioned in the post below. You use a stainless steel brush to clean the surface first and I can't remember to buy one. I got to handle a bunch of their demo items and they felt like they would hold.
: Good luck.
You can afford to try U.S. Alloys #328 for under $25.00#. It's Gauranteed to work. You also get other technical welding assistance if needed.
Neco Mateiro
07-10-1998 16:54:14
 Re: Re: "Alumalloy"??? in reply to farmer, 06-06-1998 20:27:15
Hi I saw the comercial also but I forgot to get the number did you take note of it I want to buy to try it.
Please can you email me the address and the results if you tried?
Thanks,
Neco
Drizler
09-16-1998 18:56:27
 Re: Re: Re: in reply to Neco Mateiro, 07-10-1998 16:54:14
: Hi I saw the comercial also but I forgot to get the number did you take note of it I want to buy to try it.
: Please can you email me the address and the results if you tried?
: : Thanks,
: : Neco
Tom Paisley
08-25-1998 08:56:21
 Re: Re: Re: "Alumalloy"??? in reply to Neco Mateiro, 07-10-1998 16:54:14
: : Thanks,
: : Neco
The number to order the Alumalloy is 800-917-WELD. Hope this helps. I just ordered some myself.....
Mike
06-09-1998 13:02:33
snip> At $45/pound becomes a bit pricey to try.
: : thanks
: : JerryU
snip> I got to handle a bunch of their demo items and they felt like they would hold.
: Good luck.
I've used it with good results too, but like Farmer states "you have to use the stainless steel brush". This is to avoid contaminating the base metal (the part to be repaired). Also, use a clean or new brush for best results. If the brush has gunk or rust or whatever from the last thing cleaned, the "Alumalloy" won't stick.
As I recall, "Alumalloy" is a type of solder, and is subject to all the problems you'd encounter trying to solder dirty parts...
Have you thought of using some of the regular aluminum arc welding rods (regular stick, NOT Tig or Mig)?
