2N Electrical
Dan
12-07-1999 11:55:28
Where can I find a schematic of my 2N electrical system. I have a N series repair manual but it only has the schematic for the 8N. Can I find it on-line.
Dan
JMCinAZ
12-16-1999 22:02:53
 Re: 2N Electrical in reply to Dan, 12-07-1999 11:55:28
You can find a diagram at WWW.NSeries.com
click on the "electrical wiring diagrams" link under the "maintenance" header...good luck
Bruce Schmidt
02-02-2001 10:31:12
 Re: Re: 2N Electrical in reply to JMCinAZ, 12-16-1999 22:02:53
I have a 1941 M farmal and would like to put a 12 volt gennerator on it and I need a wire diagram to install it. There is no wires there now. I have to use a battery charger to charge the battery if I use the tractor. I found a gennerator and voltage regulator with three terminals on the regulator. The original switch for the lights, charging rate and the ampmeter is still in place. Thank you
