2N generator
Dan
12-07-1999 12:03:15
I just replaced the wireing harness on my 2N. The generator always charge my battery up to this time, although the amp meter did not work. While replacing the wireing, I put a new ampmeter on. When restarting the engine, the meter shows that it is discharging. ???? What could have changed? Is there a voltage regulator on this tractor? I'm lost and any info would be great.
Thank's
Jake
12-16-1999 22:37:14
 Re: 2N generator in reply to Dan, 12-07-1999 12:03:15
If you retained the 6v positive ground chances are that the amp meter leads are reversed. Change make sure positive wire goes to ground [check w/volt meter to insure the gen is working. No regulator on this model, uses a cutout, wire from gen to amp meter
Lou Kronast
12-08-1999 22:47:08
could you have passed the wire thru the ammeter in the opposite direction? that would do it
JerryU
12-08-1999 04:23:45
Flip over to the N Board and there is a lot of help in the archives. Below is a link to a post that gives a lot of other links. Wiring diagrams are available through Neil's site - Nseries. Go there first.
Also, my good friend Tyler Neff has an excellent page:
Link
