42 Farmall B Carb Problms.
Steve Clark
06-23-1998 20:48:27
Carb is flooding out on B. Drained tank and flushed carb went to start with gas on overflows from side of carb. Can drain carb shut gas off, then will run but when line opened will stall and overflow again. any suggestions??
Red Fred
06-24-1998 02:57:29
 Re: 42 Farmall B Carb Problms. in reply to Steve Clark, 06-23-1998 20:48:27
: Carb is flooding out on B. Drained tank and flushed carb went to start with gas on overflows from side of carb. Can drain carb shut gas off, then will run but when line opened will stall and overflow again. any suggestions??
Try to tap LIGHTLY on the side of the carb., your float could be stuck. If that doesn't work, take your carb. apart and check your float and needle valve.
