3/8 industrial vs 1/4 NPT
darold
01-29-2000 16:52:57
Output from a 5 HP air compressor- why would I use a 3/8 industrial connector at the end of my hose to suppy the air to my air tools vs a 1/4 NPT connector?
Is the performance better? Does it allow more air to move? Is is better/worse on air tool wear?
Someone tell me. Thx.D
John C
02-11-2000 05:59:29
 Re: 3/8 industrial vs 1/4 NPT in reply to darold, 01-29-2000 16:52:57
3/8 connectors are for the large tools such as 1" drive impacts. You are crazy to use a 3/8 inch connector and 1/2 " hose on a 1/2" impact.
Shawn
02-01-2000 08:12:01
A buddy of mine used 1/2" Industrial connectors on his air hose, thinking that bigger is better. The big problem is that is takes a couple of healthy young football players to connect them! I imagine the 3/8" would be a little easier but if you don't have a strong handshake I would stick to the 1/4" couplings.
DC Dale
01-30-2000 13:01:32
Most shop air hoses are 3/8 hose with 1/4 npt couplers. This set up will carry all the air you need for up to 3/4" impact wrenches. You may want to go 3/8 or 1/2 hose with 3/8 couplers for the larger impact tools .
John
01-30-2000 09:34:49
If by 3/8's industrial connector you are talking about a quick coupler the advantage is obvious.
