Super C Vs. "M"
Harold
05-26-1998 18:00:51
I have a Super C with two-point-hitch. Will my two-point-hitch implements fit on an "M"? My hydraulic pump does not work. Can it be rebuilt? If so where or by whom?
Thanks
Harold
Harold H
05-27-1998 04:39:15
 Re: Super C Vs. "M" in reply to Harold, 05-26-1998 18:00:51
: I have a Super C with two-point-hitch. Will my two-point-hitch implements fit on an "M"? My hydraulic pump does not work. Can it be rebuilt? If so where or by whom?
: Thanks
: Harold
Harold,
Roger has already answered your question. Just to add comment, although the Super M was never offered with a two point hitch, the Series III Super M's could be fitted with a two point hitch from a 400, 450, or 560 as the rear housing was cast and drilled for mounting the hitch. Some pre-production two point hitches were also fitted to the Super M for field testing when new. Any kind of way however, this two point hitch is bigger than the Super C two point hitch.
Harold H.
Roger
05-26-1998 19:56:59
: Thanks
: Harold
I have never seen an "M" with a two-point hitch, but there are different sizes of two-point hitches on IH tractors. The one on your Super C is the smaller one and will not fit implements built for larger tractors like the IH "400" for example. I have a Super C that I just restored. I had trouble finding a hydraulic pump and finally rebuilt it myself, since it wasn't in too bad shape. Later I found out from my neighbor that he got one from: Smith Implement Co., Tractor Parts, Downing, WI 54734 phone 1-800-472-2815. They have some new, rebuilt, and salvaged parts. I'd give them a call.
Roger
BOB MCCAMMON
05-27-1998 17:47:44
 Re: Re: Super C Vs. "M" in reply to Roger, 05-26-1998 19:56:59
: : : I have a Super C with two-point-hitch. Will my two-point-hitch implements fit on an "M"? My hydraulic pump does not work. Can it be rebuilt? If so where or by whom?
: : Thanks
: : Harold
: I have never seen an "M" with a two-point hitch, but there are different sizes of two-point hitches on IH tractors. The one on your Super C is the smaller one and will not fit implements built for larger tractors like the IH "400" for example. I have a Super C that I just restored. I had trouble finding a hydraulic pump and finally rebuilt it myself, since it wasn't in too bad shape. Later I found out from my neighbor that he got one from: Smith Implement Co., Tractor Parts, Downing, WI 54734 phone 1-800-472-2815. They have some new, rebuilt, and salvaged parts. I'd give them a call.
: Roger
ih did furnish spacers so that implements with the small prongs could be used on tractors that had the larger two point sockets
