Tractor Talk Discussion Forum
allis C wd wc whats differance
roger roland
06-07-2007 21:28:13
im not a allis c person dont know anything about them other than there ugly period. whats the differance between wd or wc ? got a chance to pic up one but dont know what it is & its cheap enough to make worth my time
J.C. IN AZ.
06-08-2007 11:18:10
 Re: allis C wd wc whats differance in reply to roger roland, 06-07-2007 21:28:13
If you think they are "Ugly" why are you bothering? Going to "Scrap" it out"
old
06-07-2007 22:11:21
WC and WD use the same engine but the tranny is differant in them. The WC will have a shifter that is more forward and the WD has the shifter back towards the rear end. Also the WC doesn't have a hand clutch and the WD does. Also the WC do9esn't have hyds and the WD does
dan hill
06-08-2007 04:41:23
 Re: allis C wd wc whats differance in reply to old, 06-07-2007 22:11:21
WC had hand brakes, must have been tough to drive.
Bill(Wis)
06-08-2007 04:59:46
 Re: allis C wd wc whats differance in reply to dan hill, 06-08-2007 04:41:23
The C is smaller than WC or WD. More like a B but had narrow front end and rear tread was wider. WC with hand brakes was not difficult to drive as the clutch was foot operated as was the cultivator lift (if you had a mounted cultivator). Coming to the end of the row you could throttle back, raise the cultivator with the right foot operated pedal, steer with steering wheel assisted by hand brake, turn 180 degrees, straighten out, drop cultivator and throttle back up. No clutching needed unless you wanted to stop for something but you had left foot free to do that in any case. We had the rear wheels set out wide at that point in the year. For cultivating those wide rows. By the time I was 8 years old I could do all of that with no problem
