Tractor Talk Discussion Forum
Homemade apple grinder
Zachary Hoyt
09-22-2015 10:04:23
third party image
third party image
third party image
Here are a few pictures of the apple grinder. It is very simple and easy to make. The screws are in 8 rows, each screw is 1" apart in each row and each row is offset 1/4" from the one before it so there are no gaps. I have to use a pusher board sometimes to get the apples not to jam up above the drum. I use a piece of 1x8 about 18" long to push. The drum is ash, most of the rest is hickory. I am hoping this winter to make a hand cart out of 8/4 ash boards that will have the press on one end and the grinder on the other. Right now it is just sort of perched on the stairs so I can put the bowl underneath. The press is very old and I want to replace all of the wood since it is not as rigid as I would like.
Zach
Dave H (MI)
09-22-2015 18:13:41
 Re: Homemade apple grinder in reply to Zachary Hoyt, 09-22-2015 10:04:23
Looks pretty nice. Some of the old ones don't grind fine enough. Yours looks like it would tear them up pretty good!
IA ROY
09-22-2015 10:58:07
A friend of mine made one out of a new garbage disposal some years ago and was pleased at the job it did
Zachary Hoyt
09-22-2015 11:26:22
 Re: Homemade apple grinder in reply to IA ROY, 09-22-2015 10:58:07
When I got the cider press it came with one of those and it did a fine job, but to grind a bushel of apples took 1-1/2 or 2 hours and sometimes after a while it would get hot and trip the thermal reset. It did grind the apples very fine, though.
Zach
