Tractor Talk Discussion Forum
JD front pumps on TLB why won't they interchange ?
Bser
06-10-2007 19:44:37
I have a 510B hoe with a bad front pump;I'm told it MUST come off a like machine; why? virtually all trctors ,hoes and small dozers have a similar sized pump.Is this another JD gotcha or is there a real reason? Anybody sell rebuilt units? How about a source of a used one? I could really use help to get this machine going.
Bob
06-10-2007 19:57:24
 Re: JD front pumps on TLB why won't they interchan in reply to Bser, 06-10-2007 19:44:37
Go to jdparts.com, and select "John Deere Parts Catalog". (You DON'T have to register, or even sign in to look up parts. IF you want to price them, or check local dealer stock, you have to be registered.)
You can then look your machine up (with serial number), and see what pump it uses, then look up whatever other machines you have acces to, and see if any pump part numbers match.
Note... Deere made several pumps similar in outside appearance, but with a variety of different displacements. That MAY at least partially be what determines what pumps will interchange.
