Tractor Talk Discussion Forum
broken steel bolt in cass steel
Ronald Walls
06-12-2007 14:56:07
Need help getting this sucker out. it is flesh to the cass steel. and a friend, who the mower belongs broke a drill bit off in it to. think i will try welding ,henrob welder, a nut on top and taking it out. unless someone can come up with something better. only one end showing.
Russ from MN
06-12-2007 15:09:10
 Re: broken steel bolt in cass steel in reply to Ronald Walls, 06-12-2007 14:56:07
A procedure that works well sometimes is, lets say its a 5/8 bolt, weld a heavy 1/2 flat washer to it, welding all around the inside of the washer, with 7018 or better. Then, weld a nut to the washer, welding all around the outside. Let it cool a little and try working it back and forth. Good luck!
dds-inc
06-12-2007 15:05:28
Burn it out. get the pointiest flame you can get and stick it in there and burn it.
Smoke Wrench
06-12-2007 16:33:11
 Re: broken steel bolt in cass steel in reply to dds-inc, 06-12-2007 15:05:28
Yep. You shold be able to blow it out and never nick theads. Chase them when you're done just to clean them up.
dds-inc
06-12-2007 19:02:58
 Re: broken steel bolt in cass steel in reply to Smoke Wrench, 06-12-2007 16:33:11
It HAS worked pretty well, provided that you're careful with that darned torch tip and the direction to which you're pointing. Once, I messed up by holding it on an angle, burning a little of the threads off. But i've done 10 or so holes with success since.
