Tractor Talk Discussion Forum
hydrolic cylinder
jonathan s
06-13-2007 18:01:03
hey guys i have an old john deere hydrolic cylinder. i heard that it was a low pressure cylinder and wouldn"t be able to lift my brothers haybine. is this true or am i ok to us it on the haybine. thanks again guys. jonathan s in northeastren pa
jonathan s
06-14-2007 11:13:35
 Re: hydrolic cylinder in reply to jonathan s, 06-13-2007 18:01:03
hey, thanks guys
Allan In NE
06-14-2007 00:41:52
It will lift that mower just fine.
Allan
JMS/MN
06-13-2007 20:17:57
The important thing is that you use it on a tractor that develops the same pressure- not higher. If it is made for a two-banger and you hook it to a New Gen- you'll burst the housing.
msb
06-13-2007 19:32:16
Try it. A 3" cylinder with 1,000 PSI pressure will develope up to (approx.) 7,000# of lift capacity. The same cylinder under 2250psi will develope up to (approx.) 15,750# of lift.If the old cylinder will handle that much additional pressure,(if needed) it will work just fine.Any cylinder will only develope enough pressure to meet the demands of the load---until it reaches the end of its stroke.
nhboyd
06-13-2007 18:12:13
yes it's true. the old systems were 800 to 1000 psi. haybine will need close to 1500 to 2000
