HYDRAULIC PROBLEM J.D. 2010
TOM
01-20-1999 17:54:24
I HAVE A JOHN DEERE 2010, GAS. JOHN DEERE LOADER.
SINCE COLD WEATHER, HYDRAULICS AND POWER STEERING
WONT WORK, OR ONLY FOR 20 MINUTES AT MOST, BEFORE
QUITTING. J.D. DEALER DRAINED HYDRAULIC FLUID,
CLEANED FILTER(WAS NOT DIRTY)REPLACED WITH NEW FLUID. IN WARM SHOP, WORKED OK. OUTSIDE, IT RAN
2 HOURS BEFORE QUITTING. ENGINE RUNS AND STARTS FINE, NO TRANSMISSION PROBLEMS. ANY SUGGESTIONS?
wendell schofield
10-20-2006 11:57:02
 Re: HYDRAULIC PROBLEM J.D. 2010 in reply to TOM, 01-20-1999 17:54:24
i have a2010rjd the lift will operate without any weight. I put a new pump on it and rebuilt the rockshaft. it is a dual rockshaft. any comments welcomed
jeff
01-21-1999 09:34:31
I AGRRE WITH TIM,CHECK YOUR HYDRAUIC PUMP CONNECTOR FIRST. NEXT YOU NEED TO MAKE SURE YOUR GETTING A GOOD SUPPLY OF OIL TO YOUR MAIN PUMP. THEY DO NOT CREATE A VACUMN & WILL NOT 'SUCK' OIL. YOU HAVE A TRANSMISSION PUMP THAT LUBRICATES THE TRANNY & PROVIDES HEAD PRESSURE TO MAIN PUMP INLET. THE TYPE OF TRANNY PUMP DEPENDS ON WHICH TRANNY YOU HAVE. SYNCR IS SIMPLE GEAR PUMP. YOUR MAIN HYDRAULIC PUNP IS VARIABLE DISPLACMENT. NOT REALY ALOT TO GO WRONG ON THEM--NOT FUN TO GET OFF THOUGH. IT MIGHT HAVE A VALVE STICKING
Tim
01-20-1999 19:05:31
Check the splines on the hydraulic pump and the coupler. They may be worn.
Grant
01-20-1999 19:30:48
 Re: Re: HYDRAULIC PROBLEM J.D. 2010 in reply to Tim, 01-20-1999 19:05:31
Sounds like the pump itself. Only other thing is the relief valve, but thet should do it all the time. I think it is probably a pump problem
randy
01-20-1999 18:33:55
tom
does the pump start to rattle before it quits or does it just quit? e-mail me with info and we'll try to figure it out.
randy
bruce's repair shop
qulin mo.
