Tractor Talk Discussion Forum
Herbicide on hay killing broadleaf plants
Heyseed
06-16-2007 09:48:46
Hi all, I know a lot of you have experience with crop chemicals and was interested in your input on this situation. We"ve spent the last 10 days diagnosing a serious problem affecting large numbers of our plants. We"ve recently concluded, with the help of our extension office and farmer friends, the damage is from very small herbicide residues (likely Picholran or 2-4,D; both of these target broadleaf plants and have no visible impact on grasses) on the hay we bought and used for mulch.
john cub owner
06-16-2007 20:28:39
 Re: Herbicide on hay killing broadleaf plants in reply to Heyseed, 06-16-2007 09:48:46
Several years aog I brought a load of rice hulls form my in-laws in central Ar. to use as mulch on my garden plants in eastern Mo. Boy was that a mistake. It was 2 or 3 years before I had a decent garden again. I assumed it was form the herbicides they use on the rice.
Matt from CT
06-16-2007 14:06:50
FWIW, on the organic gardening side (I'm "semi" myself as I will occassionally use limited chemicals, etc) lawn grass clippings from unknown sources -- i.e. picking them up from the town dump or having a landscaper drop them off has been known to have this same impact on gardens from residual chemicals that people applied to their lawns.
Jerry/MT
06-16-2007 11:35:34
Picloram is most likely the problem. It's active in the soil and doesn't readily breakdown. Washingto State University(WSU) had a problem about 5 years ago with composting plant material that had Picloram in it. As I recall,they sold the compost and the Picloram was still active AFTER the composting and caused a lot of plant mortality for those folks who used it. There was a lot of lessons learned from that experiece. I doubt that 2,4-D was your problem however. The label allows use on pasture with grazing after 7 days. Unlike Picloram, it breaks down very quickly.
paul
06-16-2007 13:08:09
 Re: Herbicide on hay killing broadleaf plants in reply to Jerry/MT, 06-16-2007 11:35:34
I heard the same stuff Jerry, agree with you.
--->Paul
What input?
06-16-2007 10:06:55
You've already solved your problem. Doesn't seem like you need any more input.
heyseed
06-16-2007 10:11:46
 Re: Herbicide on hay killing broadleaf plants in reply to What input?, 06-16-2007 10:06:55
Thanks, what I was interested in is how long will it continue to be an issue. Is there any way to mitigate the damage. Should I try to flush the affected soil with extra water.. that is the type of input I was hoping for....
Walt Davies
06-16-2007 13:43:25
 Re: Herbicide on hay killing broadleaf plants in reply to heyseed, 06-16-2007 10:11:46
Plow it up several times it should dissipate after while.
Walt
Greg_Ky
06-16-2007 11:19:13
2-4-D is a contact killer it has no soil activity.
