British Leyland
Caesar LePorte
04-16-2002 21:18:57
I am not sure what I have, it says it is a Long 425, but someone told me it was a British Leyland. It is between a 1968-1971. Do the serial numbers off of the engine block determine the model.
Jim Jelinski
08-04-2005 20:32:48
 Re: British Leyland in reply to Caesar LePorte, 04-16-2002 21:18:57
Long DID sell a British tractor.
My father-in-law owns a 'Leyland-Long model 4/25'. This is also known as a "BMC Mini" (possibly "Minnie") and was available with either a gasoline or diesel engine. His tractor was built around 1966. I had it at my place for about 10 years. The engine and cast main body (transmission housing) is a bit smaller than a Ford 8N or Fergusen TO-20, but when parked side-by-side, the overall length and rear wheel size and width is similar. It has a 'BMC' metal badge on the side of the hood towards the rear, and a "Long" decal on the side of the hood adjacent to the engine. The data plate is aluminuim, and is riveted to one of the axle housings, but I don't recall just where. The basic (gasoline) engine is VERY similar to that in an MGB sportscar. It has a 3-speed transmission with reverse (controlled by one shift lever), along with 3 gear ranges (controlled by a second shift lever) for a total of 9 speeds forward and 3 reverse. It has a 2-speed (540 RPM and 1,000 RPM at the specified engine RPM) PTO. It also has a locking differential, with the lock controlled by a lever. The gas tank is mounted below the seat and over the differential housing, with the filler mounted to one of the rear fenders.
A VERY pleasant tractor to drive.... nice power for its size, light steering, nice handling... and to top it all off, that beautiful "MGB" engine note!
Parts are available, but I don't recall the website. I seem to recall the parts people are in Tennessee. If you get stuck for a part, shoot me an Email & I will try to track them down for you.
All the Best!
Jim Jelinski
2346 Airport Drive
Diamondhead, MS 39525
Email 'lydiakj@yahoo.com'
Woodbeef
04-17-2002 10:04:23
Never heard of Long selling badge-engineered Leylands. They have sold Universals(UTB),Landini,Zetor,Framtrac,and now some from Korea (Kukje) I think.
Your tractor is probably a UTB one. Not totally sure though.
If you repost the question with the title "Long 425 questions",you'll have a better chance of getting answers.
GEO
04-17-2002 14:32:35
 Re: Re: British Leyland in reply to Woodbeef, 04-17-2002 10:04:23
Long did distibute Leylands in the 60s. They were called Long-Leylands. All I remeber was they were basically a Leyland tractor with a Long emblem on it. Then Long started importing the UTB tractor. They still sold the Leyland for a short time in the 70s as industrials. The model numbers were 3N1 and 5N1 Backhoes.
I wonder if this is where JCB started.
