Tractor Talk Discussion Forum
Fuel line fitting
Bsweat
01-18-2008 03:44:12
I am trying to identify the type of fitting on an injector fuel line. I would like to buy some new ferrule nuts. This is off of a Super Dexta with a Simms injector pump. I am guessing they are a Brittish thread, but not sure.
Thanks for your help.
combean
02-04-2008 08:32:53
 Re: Fuel line fitting in reply to Bsweat, 01-18-2008 03:44:12
Injector lines are not repairable by most 'home' mechanics. A good diesel shop should be able to make these up though. CNH dealer may be able to get them also. The dexta's used a metric fitting...threads are 12mm 1.5 'pitch' .....( the only metric fitting I've ever come across on these tractors). I discovered this while testing mine recently.
rrlund
01-18-2008 13:05:57
I don't know that injector lines are repairable are they? They aren't just a common steel line. The walls are extremely thick with a tiny little hole in them.
