How to change a front tire, Super C.
Carl L
05-16-2002 17:15:16
I have a Farmall Super C, with a single front tire that I need to change. I was told to loosen but not remove the bolts that is below the axle. Raise the tractor to remove the weight from the front tire and then remove the nuts from the axle. Then the axle can be pressed or knocked through, but not from the side of the greese fitting. Does this sound right? May I did not hit hard enough, but looks like the axle is stuck in place. Thanks to all, and have a Blessed Day (or night).
Howard
05-17-2002 05:21:36
 Re: How to change a front tire, Super C. in reply to Carl L, 05-16-2002 17:15:16
careful not to dammage the threads but sounds stuck to me.
