Misused Int 3414 backhoe transmission
Don Haponski
06-18-2002 16:52:59
Has anyone had experience with a Int. 3414 tranny, that jumps out of any gear you put it in. Sometimes the tractor will move other times it won't. The owner said it stuck in 4th and he pulled the cover to get it out. Since then the go/ no go, problem. [I don't know if that's true or a story to sell the tractor]. The price is right if it's not a major problem, but if the tranny is just worn out from misuse, the price isn't right
Thanks for any help, Don Ho.
Don H
06-23-2002 05:42:08
 Re: misused Int 3414 backhoe transmission in reply to Don Haponski, 06-18-2002 16:52:59
Thanks for the input Dave, I'm going to pull the cover and see if there,s anything tore up or just worn out bearings, before I buy it
Dave
06-22-2002 19:05:30
I have a 3514 the forward-reverser came apart it only tore up a few things. Went to local dealer for parts 2 gears, 1 fork, 3 bearings, 3 gaskets and 2 seals $2800.00 The problem is Int. is now Komatsu Dresser and they do not make parts for these old tractors. If they have the parts your Ok, if they don't tuff and they are all expensive. I went to my friendly machinist and had some of the parts made and some repaired, got out of it for $300.00 Beware if this tractor has a trany problem. They are also are hard to work on, need a good shop and lots of room.
Good Luck
steve mosher
12-12-2004 09:59:51
 Re: Re: misused Int 3414 backhoe transmission in reply to Dave , 06-22-2002 19:05:30
need your advice about the problem you had.. did you problem give you problems with the rest of the HYD ...did you have HYD drive...I guess thats what i should of asked
kc8gaz2000@yahoo.com
