Is there a brand of tractor that ran a chrysler flathead six?
Dave_D
09-20-2002 12:29:37
A friend a mine says he has an older tractor that has a Chrysler flathead six. He will give it to me for near nothing, but its a 200 mile drive. Said it did run 10 years ago. He also said the pto shaft had a chain to run the rear axle? Sounded like a homemade job to me. Anyone have a clue what type it might be.
Thanks
Dave D - Texas
Chris
11-07-2002 19:20:25
 Re: Is there a brand of tractor that ran a chrysler flathead six? in reply to Dave_D, 09-20-2002 12:29:37
Seems to me like the custom tractor ran a chrystler 6 cylinder engine. They were made in the early 50's I believe and did very good in tractor pulls. If that is what it turns out to be, it would be worth a 200 mile drive. Of course any FREE tractor is worth driving for. May be something to check into.
Dave_D
09-24-2002 10:06:38
Thanks for all the info, I will be visiting the tractor in 2 weeks. I'll take some pictures.
Thanks Again
- Daev
The Puller
09-21-2002 12:11:27
I have done some research and I have concluded the it is a Massey Harris 101 Junior, a Ward, a Rockol, or a Friday model 048. If it is a Friday model, don't let it get away.
Gordon in IN
09-21-2002 17:46:55
 Re: Re: Is there a brand of tractor that ran a chrysler flathead six? in reply to The Puller, 09-21-2002 12:11:27
The Custom Model "B" Tractor. made in Shelbyville IN. had a 6 cyl Chrysler flathead (inline) industrial engine and had a "Link Belt" reduction unit between the transmission output shaft and the differential. The "Link Belt" reduction unit is "chain" drive. The engine had the same bore and stroke, bearings, oil pump, valves and distributor as one of the 1948 Dodge Pick Up Engines and in addition had a belt driven govenor. The engines could easily be made to overpower the differential or the "link Belt" reduction unit; both were often the "failure mode" for the tractor. The engine govenor could be easily adjusted to "MUCH" higher RPM which gave more horse power. The Pick Up Engines were rated at something about 72 horsepower. I think that these engines ran quite well at 3600 RPM.
Hal
09-21-2002 04:55:13
My neighbor had two Massey Harris 33's. As I recall, one had a Chrysler flathead and the other was the more common Continental. Did any 33's come from the factory with Chrysler flathead, or would this have been a conversion?
Kevin
09-21-2002 00:26:45
Yes in a Massey Harris 101 they had them.
Farmered
09-20-2002 20:32:08
Many,MANY years ago I had a M-H 101 Junior that had a roller chain coupler between the clutch and transmission. This may be what your friend called
a chain drive. Ed
Dave
09-20-2002 19:41:41
You better have a look,might be well worth bringing home.My dad and I put this kind of engine in a '38 F-20.Great tractor! Too bad I sold it several years ago.Last I knew it still was being used.
rhudson
09-20-2002 19:00:49
also a tractor named jumbo, take the 200 mile drive. i had a chance to purchase one for $150. but like you, i was thinking "homemade". someone who knew better got it and resold it for $1500.
Dave_id
09-20-2002 18:57:54
Coop B2
Chances R
09-20-2002 16:11:34
Oh yes. Custom, Massey Harris, Lehr, Wards, Simpson, Love, Rockhol. and probally a few more that I just cant come up with. I always liked these motors. These tractors came in different cubic inch motors also, and there was a variation of the Custom, that had a straight 8.
HD
09-20-2002 14:15:52
How about the Wards Tractor. I am thinking that it was a chrysler 6 also. I remember in the 60's a fellow by the name of Johnny Engle ran one in the 5500# class and was turning it 6,000 RPM's and holding it together at that RPM's
Robert in W. Mi
09-20-2002 13:59:26
I think the one called LOVE was also crysler powered. Robert
Bob M
09-20-2002 13:57:04
The tractors Joe mentions below were indeed equipped with Chrysler flathead sixes. Seems to me there were a couple other orphan/oddball makes that also used this engine but I cannot recall what they were offhand.
Regarding the "chain drive" comment, it's possible the tractor your friend is offering has a roller chain flex coupling between the clutch output shaft and the transmission input shaft. This coupling style is found on most Oliver tractors built in the 50's and 60's, and likely was used on other makes as well.
Joe Evans
09-20-2002 12:51:20
I don't know about the chain part of your question, but the Co-op No. 2 and 3, Massey-Harris 101 R, 101 S, 101 Senior, and 101 Super had Chrysler 6 cylinders and most likely were of flat head design.
Alberta Mike
09-20-2002 14:31:29
 Re: Re: Is there a brand of tractor that ran a chrysler flathead six? in reply to Joe Evans, 09-20-2002 12:51:20
The Super 101's ran Chrysler engines, however the Senior lines had Continental engines in them. The engines looked very similar in design since both were flatheads with all the same components on the same side of the engines.
Joe Evans
09-20-2002 20:33:41
 Re: Re: Re: Is there a brand of tractor that ran a chrysler flathead six? in reply to Alberta Mike, 09-20-2002 14:31:29
I stand corrected, sir. The Seniors had Conties.
Dsl
09-20-2002 13:55:35
Yes, the tractors you mentioned were flatheads. Other tractors that used the Chrysler flathead six engines were, Friday, Custom, Norseman, and the Harris Power Horse, and no doubt more still.
Garlyn
07-18-2005 17:45:39
 Re: Re: Re: Is there a brand of tractor that ran a in reply to Dsl, 09-20-2002 13:55:35
I have purchased a "Custom" but have been unable to find any info, ie., serial number or any other info. Can anyone help?
Bryan in Michigan
09-20-2002 19:43:12
 Re: Re: Re: Is there a brand of tractor that ran a chrysler flathead six? in reply to Dsl, 09-20-2002 13:55:35
I believe the Friday tractor from Harford, Mich., similar to the Love had this arrangement as well. had Chrysler drivetrain too. It was/is very fast.
