BF AVERY Tractor parts
cheries001
09-20-2002 16:44:41
Hi,Does anyone know where I can get a Keeper for the exhaust valve for a BF Avery tractor. I think the tractor is a 1937.
Alberta Mike
09-21-2002 06:04:40
 Re: BF AVERY Tractor parts in reply to cheries001, 09-20-2002 16:44:41
I don't think you have a 1937. The BF Avery lineup started in about 41 or 42 when the model A came on the scene. It evolved from the Cletrac General GG which started production in 39. Have you found a serial number? My serial number is on the upper surface of the steel gusset that is riveted onto the rear of the right-side frame rail. That gusset attatches the frame rail to the transmission/differential unit. I have a history page on those tractors that I have made up. If you want me to email you one, hit on the above blue link of my name. Meanwhile, check for the serial number, it will be hard to find maybe since it is painted over and some weren't stamped in too deeply.
JON HUCKABEE
01-21-2005 08:48:09
 Re: Re: BF AVERY Tractor parts in reply to Alberta Mike, 09-21-2002 06:04:40
i have a tractor that a neighbor gave me. my dad says it's a 1937? avery? maybe a farmall 20 horse. it's a little 4 cylinder gas powered. with electric start. hand crank in front. the seat and steering is centered on the tractor. the serial# is on the back right side of the engine. the distributor is on the right side, exhuast manifold is on the left side. it has an open drive shaft assembly. the rearend is straight then turns downward to connect to the rear wheels. it had rubber tires at one time. it's in decent shape to restore. i have looked at numerous pictures, i have found some kind of like it but not exactly like it. i need some help to found out what kind of tractor it is.
thank you,jon huckabee
gatesville,tx.
cheries001
09-21-2002 12:09:21
The serial number on the tractor is 5A304. Thanks for any help you can give us.
