Tractor Wheel Weights for Older Tractors
Terry Goodling
10-10-2002 20:05:40
I'd like to get some feedback on a unique wheel weight system that will work with older tractors. Check out the link below and let me know what you think.
Thanks,
Terry
Mr Rollinson
12-11-2004 18:35:48
 Re: Tractor Wheel Weights for Older Tractors in reply to Terry Goodling, 10-10-2002 20:05:40
Where can i find wheel weights for my c-85 wheel horse at least 55-75 lbs for beter traction when plowin
RayP(MI)
10-12-2002 05:11:28
Or how about just drilling a couple holes in the proper places on the weights, and attaching them with bolts like conventional wheel weights?
Seamo
10-11-2002 20:45:12
Terry, I think its a good idea. Some of the antique tractor pullers use a round tube that attaches to 9 bolt hub. They just slide the std. wheel weight on and use a series of holes for 1/2 iron rod in the tube to keep weights on. Its real handy for them they can change weight classes real easy and the weight is in the right place on the tractor.Earl
Interesting Idea.........Scott (ID)
10-11-2002 09:01:05
If the dumbell weights still rotate freely, they would be "unsprung" weight and the tractor powertrain wouldn't have to waste energy to spin 'em.
Scott
teg33
10-16-2002 19:32:59
 Re: Re: Tractor Wheel Weights for Older Tractors in reply to Interesting Idea.........Scott (ID), 10-11-2002 09:01:05
The "dumbbell" weights are tightened securely against the mounting frame, they do not spin so that will not be a problem.
Dave_Id
10-10-2002 21:39:32
Are you selling these?
