M.R.S. tractors.
Roger.
12-27-2002 12:13:26
Can anyone tell me anything about these tractors? I know they have a detroit motor,how many H.P. what was the transmision,are there many still around? any info most welcome, thanks
Billdozer
12-26-2004 15:53:58
 Re: M.R.S. tractors. in reply to Roger., 12-27-2002 12:13:26
I have a 1970 MRS Mfg Tractor model 100 m69 It is rubber tired w\25" tires/4wd/4wsteer has a detroit 71 series motor & an allison trans/9ft dozer blade & 8cu yd pan. This is a GREAT old tractor w\ almost no wear but almost no maint. I need to redo hydo/pneumatic & elec sys.If anyone has any tech or parts manuals or info/moral support please contact me . The co.was a military supplier from WWII thru Vietnam. The plant was in Flora Miss. & has been closed for years.I heard that MRS stood for Mississippi Road Supply. My plan is to repair it, build me a pond & then sell it. I"ll be glad to give anyone who helps me first crack at it.
Jon from Indiana
12-29-2002 07:50:26
Have to remember back 37 Years. MRS stands for Mississippi Road Service. There was one on the navy air base at Patterson , Californa, the base name was Crows Landing. It was set up with a cable streched across runway attached to anchor chains so if a plane want to far down the runway it would hook the cable and drag the chains and stop the plane before running off end of runway. the mrs we had was equiped with a roadranger5 speed transmission and we would take it out and pull the chains back where they belonged and the airdales would hook them up, i was in the seabees. i imagine you could order them anyway you wanted. JOn ( sorry i got so long winded)
Roger.
12-29-2002 18:17:35
 Re: Re: M.R.S. tractors. in reply to Jon from Indiana, 12-29-2002 07:50:26
Jon, thanks for your comment,been talking to a guy who has one for sale and although it needs a lot of work it might be worth it.Has duals on it as though its been used for farming,would I be correct to think they were more of construction type tractor?
