Inernational McCormick B414 Diff problem
leebox
02-02-2003 04:38:17
Could some please tell me how to refill the Diff on a 1950's to 60's International McCormick B 414 as i am unable to find the filler hole
Lee Box
09-02-2004 10:09:09
 Re: Inernational McCormick B414 Diff problem in reply to leebox, 02-02-2003 04:38:17
Just saw the name.
wondered if it was your real name.
Shawn
02-02-2003 11:25:38
I filled my 414 from the filler plug under the seat, should be on the right and side towards the rear....i think..... ...and take the check plug out to see how full its getting. Good luck Shawn
Ronnie
02-02-2003 05:27:48
Look to the right side of the gear lever.The trans. and diff. use the same oil. The check plug is on the left side under clutch pedel. Hope this helps. Ronnie.
Gary
02-03-2003 18:22:15
 Re: Re: Inernational McCormick B414 Diff problem in reply to Ronnie, 02-02-2003 05:27:48
That plug on the rightrear only checks and fills the hydraulics
