Stumpjumper
stuck and stone
04-23-2003 21:06:35
I just inherited an old 5' brushhog called "Volunteer". I hit a big rock cutting a pucker brush field the other day and now the stumpjumper isn't rotating level though it's on nice and snug. The bolts that hold the blades are scraping against the deck in one spot slightly. Does this mean I bent the shaft? Or is there a way to realign the stumpjumper? If I did bend the shaft a little can I just file down the bolts so they clear the deck and still run the thing without doing damage to the gear box?
mdm
04-30-2003 11:56:31
 Re: stumpjumper in reply to stuck and stoned, 04-23-2003 21:06:35
I see three things you could have done.
1. Bent the shaft
2. Bent the stump jumper
3. Misaligned the gear box by bending/cracking the deck/gear box mount, elongated/enlarged gear box mounting bolt holes.
With cases 1 & 2, you will see a "wobble" as the stump jumper rotates. To determine whether it is the shaft or the stump jumper you may have to remove the stump jumper so you can measure radial end play on the shaft. Either of these problems can cause vibration. If the vibration is intense enough, you can cause further damage to the brushhog and possibly the pto shaft, pto and other tractor drive train components. If things break loose, you are a potential emergency room visitor (or worse).
In case 3, the stump jumper will not "wobble" as it rotates. The high point will stay in the same place in relation to the deck. If the deck/gear box mount is bent, there may be cracks or broken parts that need attention. The cracks or broken parts may allow movement of the gear box during operation. Elongated/enlarged bolt holes can also allow movement of the gear box during operation. Gear box movement during operation can cause vibration, increasing damage as you continue to use the brushhog. And again you can cause damage to the pto shaft, pto, and other tractor drive train components.
Take the time to find out just what is damaged and take care of it.
Farming has the second highest fatality rate of any industry in the country. Only mining is worse. Continuing to use unsafe equipment will help us beat miners in fatalities.
mdm
johnny mills
06-07-2004 16:10:14
 Re: Re: stumpjumper in reply to mdm, 04-30-2003 11:56:31
CAN YOU TELL ME HOW TO REMOVE MY STUMPJUMPER? I'VE REMOVED THE BIGG NUT. WHAT ELSE?
Tractor Dan
04-24-2003 05:53:00
if it bent the shaft it is possible it will through it way out of balance, it just bent stumpgumper the problem with fileing bolts down is it is possible for those blades to move quite a bit at the ends even when the bolts are tight so the blade end could float up alittle and it will peel that deck open like a can opener i have rebuild alot of decks that people have opend up you would be amazed how thick of steel one of those blades will open up at operating speed
