Hydraulic oil
Bev
04-29-2003 12:55:55
What modern hyrdraulic oil is suitable for a B250 tractor. In the handbook it says SAE20 but my agricultural store says this is no longer made. Any suggestions please? The oil is for the hyrdraulics not the transmission.
Night Stalker
04-29-2003 21:57:53
 Re: Hydraulic oil in reply to Bev, 04-29-2003 12:55:55
You can use 30 weight NON DETERGANT Oil in the hydraulic systems in the Farmall letter series tractors, not sure if this applies to others or not.
DO NOT USE DETERGANT OIL, IT WILL FOAM.
NS
Ben in kY
04-30-2003 02:19:24
 Re: Re: Hydraulic oil in reply to Night Stalker, 04-29-2003 21:57:53
The 30 W oil might be a bit too thick to work well in colder weather.
shaggy
04-29-2003 21:14:48
I was told you could use 30wt motor oil is this true? I put hytran in my 52 superA and it works just fine.
Red Dave
04-29-2003 14:40:30
By B-250, Do you have a British made International B-250?
Almost every International Harvester tractor uses Hy-Tran. I'm not positive about the British built tractors, but the U.S. built tractors use it.
You can get it from a Case/IH dealer, they would also be able to tell you if it is right for your tractor too.
Ben in ky
04-29-2003 19:21:44
 Re: Re: Hydraulic oil in reply to Red Dave, 04-29-2003 14:40:30
Hytran is 20W I believe. You can also find other oils that meet Hytran specs for a lot less than Hytran. Not sure about your tractor, but almost all Internationals I have seen will use Hytran ( or equiv) in hydraulics/transmission.
eugene wilke
04-09-2004 12:48:21
 Re: Re: Re: Hydraulic oil in reply to Ben in ky, 04-29-2003 19:21:44
i need oil specs for all locations for a d14 allis chalmers tractor.
Robert in W. Mi
04-30-2003 06:46:31
I like Hytran! I don't use the "other" stuff because Hytran will suppend more moisture in it and the "cheaper" oils. (condensation) This means when i drain it the water comes out. The water also isn't sitting in the low area's rusting the metal. I do think Hytran is worth the extra it cost, and really it isn't that much more considering how long the change intervilles are for trans/hydraulic changes. My tractors get Hytran! Robert
Ben in KY
05-01-2003 09:42:59
 Re: Re: Re: Re: Hydraulic oil in reply to Robert in W. Mi, 04-30-2003 06:46:31
Robert, do you mean that if the cheaper oil meets IH BD 6 specs it is still does not have the additives to absorb as much water ?
Ken
04-29-2003 22:18:40
Bought some HyTran yesterday for $8.99/gallon at Case International dealer.
Not too bad to get what is recommended.
Ed
04-29-2003 21:07:32
Hytran or it's equivlant will work fine. Detergant oils will foam.
