Hydraulic trouble
Ron Tompkins
06-01-2003 06:07:41
I just bought a Ford 850 with a "Lord" loader and "Sherman" Power digger. The hydraulics seemed to work fine (with the exception of the loader leaking down). After using the hoe for ten minutes the crank mounted pump started to squeal and nothing moved when trying to move any of the hydraulics. The hydraulic fluid is kind of "milky".
Could this problem be the pump?
Could it be hydraulic fluid quanity or quality?
Does hydraulic fluid ever just need to be replaced?
What are my replacement options?
Thanks ...Ron
JMS/MN
06-01-2003 13:45:58
 Re: Hydraulic trouble in reply to Ron Tompkins, 06-01-2003 06:07:41
Milky hydraulic fluid indicates water in the oil. Drain and refill with the proper oil. Sqealing usually indicates a starved pump= plugged/restricted filter.
Ron T.
06-02-2003 05:45:48
 Re: Re: Hydraulic trouble in reply to JMS/MN, 06-01-2003 13:45:58
Thanks for your help.
I can see this is going to be one of those "learn on the job" things. Seeing as this tractors needs alot, there's an chance I might learn something.
CHARLES CLARK
06-03-2003 09:55:03
 Re: Re: Re: Hydraulic trouble in reply to Ron T., 06-02-2003 05:45:48
water get into hyd system over a period of time.
control valve gets rusty and sticks. hyd system won't work .requiring teardown and cleaning.
is there a adtive to oil to dry up water???
Ben in KY
06-03-2003 12:49:20
 Re: Re: Re: Re: Hydraulic trouble in reply to CHARLES CLARK, 06-03-2003 09:55:03
HY-TRAN or good equivalent suspends water, but does not dry it up. You would have to change the fluid to get rid of it.
CHARLIE
06-03-2003 17:16:40
 Re: Re: Re: Re: Re: Hydraulic trouble in reply to Ben in KY, 06-03-2003 12:49:20
Thanks for info Ben Every year i have same promblem. Can't figure where iam geting the water from . Both shift levers have a rubber boot in place. My fergerson is a 1959 0r 1960 model 35. Also have a 1953 or about to 20 Iam restoring to orignal. have owned them botth for over 30 years.
Jack in RI
06-23-2003 15:44:28
 Re: Re: Re: Re: Re: Re: Hydraulic trouble in reply to CHARLIE, 06-03-2003 17:16:40
My dad has as Sherman 54c100 with the same water problem. What is the best place to drain and where can we find the filter. The Hydraulics work, but are very slow, so I think we have a partial clog/restriction in addition to some water.
Also, anyone know where we can get a Powerdigger manual?
geok
06-01-2003 09:02:01
Is fluid milky after it has been setting overnight? You may have a pickup screen partly blocked and or air is being sucked in on the main feeder line going to the pump causing fluid to foam.
Ron T.
06-02-2003 05:42:44
 Re: Re: Hydraulic trouble in reply to geok, 06-01-2003 09:02:01
Yes, the fluid remains "milky" overnight.
Not knowing much about these things, I would imagine the pickup screen/filter is located at the reservoir, not at the pump. Thanks for your help.
rod
06-02-2003 11:33:37
 Re: Re: Re: Hydraulic trouble in reply to Ron T., 06-02-2003 05:42:44
could the keyway on the shaft to pump be sheared off I would check that first if it is a front mount pump the key can shear off
regards
rod
Ron T
06-04-2003 08:36:26
 Re: Re: Re: Re: Hydraulic trouble in reply to rod, 06-02-2003 11:33:37
After the tractor set for a while it worked okay. Someone told me that if the hydraulic fluid temperature got hot enough the suspended water in the fluid would go to steam and "starve" the pump, causing the squeal. The other possibility could be a clogged filter in the fluid resevour.
thanx Ron
