Massey Ferguson 202 problems??????
Brad in Virgini
06-03-2003 05:42:59
I just inherited a project tractor from my father in law and it has some problems but seams to be a great tractor but needs some love. First I will tell you what it is doing and hopefully you guys can point me in the right direction. The 3pt. hitch will lift slow under a load and will not lift if the clutch is in. I know that it doesnt have the live pto right now. Is it possible to put live pto on it. It has a leaver to change it from ground speed to ind. on the side. Anyways the power steering works ok when the engine is reved but not hardley at all when the throttle is down. The pto seems to turn the same speed as the motor. I hooked up to the tedder with it and to make the tedder turn the right speed I had to have the tractor idleing. Any thoughts on where to start?? Also how many of these were made??? Are they very sought after???
Twood
06-03-2003 19:08:58
 Re: Massey Ferguson 202 problems?????? in reply to Brad in Virginia, 06-03-2003 05:42:59
I had trouble with the 3pt on my 202 when I first used it also. Mine would not even lift. I drained the old fluid and put in a 50/50 mix of fuel and clean oil, then ran the tractor a little to flush the system out, and drained and replaced the trans/hyd oil. I have the duel stage clutc where if it is pushed half way down the trans. is disengaged and all the waydisengages the hyd and pto. The power stearing usully leaks at the cylinders check the fluid in the resevior. I do not have the ground driven pto just a lever on the side to engage or disengage. I really like mine I have a loader on it and use it a lot. Parts are available because they cross with other MF models the biggest problem I have is that most of the parts people I've delt with can't find/cross the parts because it's an industrial model.
Dwayne Townsend
05-07-2004 07:05:58
 Re: Re: Massey Ferguson 202 problems?????? in reply to Twood, 06-03-2003 19:08:58
I just bought my MF202 and I'm having throttle linkage problems. I bought the missing compensator spring and link, but I still have a problem... when running and I try to throttle down, it only drops to about 1000 rpm. I have to reach down and turn the main throttle rod that runs from the dash to the front of the tractor by hand to get it to throttle back down. I compressed the spring more to no avail. I think there may be something missing that helps pull all the way back. the fitting that turns the rod (not the one that's connected to the hand control, but the one that's actually on the rod that compresses the other) has something on it that may be a broken spring mount or something... If I could even just see a picture of what that is supposed to look like, that would be a great help.
