110 JD spitting oil
Kelly Leonard
06-16-2003 13:33:20
I have a 64 JD 110 w/8hp Kohler engine. The engine runs fine although it is spitting oil from the valve plate breather hole. I am not sure where to start with the troubleshooting. If someone has experienced the same or knows anything, your advice is appreciated. Thanks, Kelly
G Taylor
06-17-2003 10:11:04
 Re: 110 JD spitting oil in reply to Kelly Leonard, 06-16-2003 13:33:20
One of my son's 110 does the same thing. If reving above 3600rpm, slow it down, that helps some. I found the crankcase level high a few times and smelled of gasoline. Had to replace the carb float/seat/needle. Plus the engine is getting tired with lots of blowby, the gases have to leave the crankcase somewhere.
