Massey Ferguson 135 Oil Leak Problem (Pressure)
Steve Allen
06-18-2003 05:10:11
I have a Massey Ferguson 135 ((Perkins 3 cylinder diesel engine)) that is slobbering oil out of the dipstick. I have replaced rings twice to make sure of no leakage and replaced head to confirm no leakage. Also have replaced oil pump. Air pressure is building up in engine and forcing oil out the dipstick. Does anyone know what could be causing this problem? Help any suggestions will be appreciated.
davidval
06-18-2003 06:19:48
 Re: Massey Ferguson 135 Oil Leak Problem (Pressure in reply to Steve Allen, 06-18-2003 05:10:11
there should be no pressure at the crankcase. there is a vent tube at the valve cover.mayby it's clogged or the hose connected to it.
however in many engines, when you remove the dipstick with the engine running oil will spray out of the dipstick tube even when well vented.
david
Burrhead
06-18-2003 06:10:35
The 1st thing I would check is to be sure the crankcase breather tube is not stopped up.
If the crankcase breather is'nt stopped up then it's either a broken compression ring, cracked sleeve or bursted piston. If somebody has used ether or gas fumes to crank it with then it could be all 3
