Carburetor QUESTION
Zenith
Mike D.
06-19-2003 10:50:42
I'm doing a rebuild on a Zenith carb. The main jet is pitted. Is it possible to buy new main jet assemblies for Zenith updrafts?
Alberta Mike
06-19-2003 13:27:48
 Re: Carburetor QUESTION - Zenith in reply to Mike D., 06-19-2003 10:50:42
When you say the main jet, are you referring to the big fuel nozzle (brass) that sticks up at an angle? If so, yes I've seen them in some kits. There is a good article on rebuilding carbs in the "articles" section in the left menu here at YT. If you go to remove the old nozzle, make sure you heat things up good with a plumbers propane torch or even in a barbeque oven or you will twist the old one off in the casting. The heating thing should only be done if the casting is cast iron ... I'm not sure if a pot metal casting would be OK with that method.
glo morelock
04-16-2004 14:11:24
 Re: Re: Re: Carburetor QUESTION - Zenith in reply to Mike D., 06-19-2003 14:22:56
My carb. is blowing gas out of 2 holes, just before the gas gets into the carburetor, can you help me understand what is going on?
Alberta Miake
06-19-2003 15:19:44
That "end" you refer to would be the threaded ends of the fuel nozzle right? There is a thread at the very end, then just plain brass, then some more threads? Some tiny little holes are drilled through the brass pipe between the threads and then again above the second set of threads? Somehow I think you should be OK ... maybe coat the threads with some of that coppercoat anti-seize before reinstalling.
Mike D.
06-19-2003 16:11:27
 Re: Re: Re: Re: Carburetor QUESTION - Zenith in reply to Alberta Miake, 06-19-2003 15:19:44
That 'end' is the needle part of the main jet adjustment assembly, that's what these instructions say anyway... The side is eroded with some heavy corrosion. I buffed on it some with a nylon pot scrubber, no emory or sandpaper though.
All the other parts showed bad wear. The throttle shaft only had one of the 2 rubber seals left.
The pin that the float lever arm is fastened to was badly scored. The screws that held the body of the carb together looked like someone had used a dull knife blade or can opener on them. I filed off the burrs.
The main jet piece has a bad gouge where someone had tried to loosen it with a mismatched screwdriver. The plug that covers the main jet looked like a pair of channelocks where used on it. I got that filed down and it can be removed with a socket now. The venturi looked like an icepick had been poked into it. That took the longest to get looking right. All in all the carb was needing a redo many moons ago. When I bought the tractor the guy said he had just rebuilt the carb. Man, I hope he is just a bad liar and not a mechanic... whew, what a mess.
Alberta Mike
06-19-2003 17:17:33
 Re: Re: Re: Re: Re: Carburetor QUESTION - Zenith in reply to Mike D., 06-19-2003 16:11:27
I think that needle you refer to is the "high speed jet" if I'm not mistaken. Yes, some of that old stuff has really been butchered. Let us know how you make out when things are back together and hopefully running.
Mike D.
06-20-2003 04:04:29
 Re: Re: Re: Re: Re: Re: Carburetor QUESTION - Zeni in reply to Alberta Mike, 06-19-2003 17:17:33
You betcha. I hope to have some good news to share. I did read those earlier posts before I statred the rebuild. I had my torch and oven mittens on the bench as I started. That PB Blaster stuff worked like a charm. I thought I would try to loosen the 4 screws that hold the thing together first. They came out very easily.
Do you know if I can buy that needle valve assembly (high speed jet) anywhere if I need it?
I appreciate you comments. Take care up there- Mike D. (Virginia)
Alberta Mike
06-20-2003 10:29:11
 Re: Re: Re: Re: Re: Re: Re: Carburetor QUESTION - in reply to Mike D., 06-20-2003 04:04:29
Can't remember seeing those in any kit. Your best bet is to keep your eyes open for an old carb(s) at swap meets, etc. and then buy it. Sometimes you can get a pail of them for $10 (which I've regretably passed on once).
AHH, NUTS.....
06-20-2003 20:19:49
 Re: Re: Re: Re: Re: Re: Re: Re: Carburetor QUESTIO in reply to Alberta Mike, 06-20-2003 10:29:11
I had hoped that you had the magic answer on this one... oh well,
Once again, much obliged. If you ever find yourself in the southern clime give a shout.
M.D./VA.
Alberta Mike
06-20-2003 20:30:31
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Carburetor QUE in reply to AHH, NUTS....., 06-20-2003 20:19:49
There are some advertisers in the Antique Power Magazine that specialize in old tractor carburetors. Tomorrow I am going to check out some back issues and I'll post some of their websites or email addresses for you.
that is good news
06-22-2003 10:51:28
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Carburetor in reply to Alberta Mike, 06-20-2003 20:30:31
I'll look for the info- Thanks again up there Mike.
