Perkins 3.152, what tractors was this engine fitt
nick
06-23-2003 06:15:54
Can any one tell me what tractors were fitted as standard with the perkins A3-152 diesel.
Rlach
06-23-2003 17:19:07
 Re: Perkins 3.152, what tractors was this engine in reply to nick, 06-23-2003 06:15:54
Landini DT55, DT6060, Fordson Super Dexta (Dexta uses 144 CID), MF 2135, MF20...
Rlach
Burrhead
06-24-2003 12:06:24
 Re: Re: Perkins 3.152, what tractors was this eng in reply to Rlach, 06-23-2003 17:19:07
You're right.
The pistons and sleeves are different between a 144 and 152cid Perkins but the blocks are the same.
Dsl
06-23-2003 15:42:59
AC 160, 6040, McKee Ebro 350.
Gord Skiffington
08-11-2005 16:20:59
 Re: Re: Perkins 3.152, what tractors was this eng in reply to Dsl, 06-23-2003 15:42:59
Actually the EBRO 350 uses the D3.152....some slight differences I believe between the A3.152 and the AD3.152
nick
06-23-2003 10:41:53
Anything else (tractor wise)?
Burrhead
06-23-2003 11:21:05
 Re: Re: Perkins 3.152, what tractors was this eng in reply to nick, 06-23-2003 10:41:53
Ford used them too on Dextas,, Super Dextas and New Performance 2000 models. Massey still uses the 152 Perkins on the 231 and 231S.
A whole bunch of genset and irrigation pump companies use it still.
Burrhead again
06-23-2003 11:32:04
 Re: Re: Re: Perkins 3.152, what tractors was this in reply to Burrhead, 06-23-2003 11:21:05
I almost forgot a couple of tractors. IMT and TAFE still use the 152 Perkins under off brand licence in India and Yugo. They don't call them a Perkins but all the engine parts except the injector pump will interchange with Perkins OEM.
Chip
06-23-2003 08:03:42
Massey Ferguson, 35.
Bus Driver
06-23-2003 17:08:54
 Re: Re: Perkins 3.152, what tractors was this eng in reply to Chip, 06-23-2003 08:03:42
Also the Massey 135, 235, 240, 245, 250 and the old model 150, just to name a few.
David
06-24-2003 03:02:40
 Re: Re: Re: Perkins 3.152, what tractors was this in reply to Bus Driver, 06-23-2003 17:08:54
Compair compressors, JCB 406 loading shovel. Hunnerds of machines used this engine.
There are several variants 3.152 (indirect injection), D3.152 (direct injection), AD3.152 (direct injection made for Massey Ferguson applications).
