Bobcat 743B Fuel Problem?
Stephen Shepher
07-05-2003 17:03:10
I have a Bobcat 743B Diesel with 2000hrs on it. I am having what seem like intermittent fuel problems. The unit will run fine for 1-5minutes then it will die. Pumping the fuel primer ball seems to revive it temporarily. I have replaced the fuel filter and the fuel looks clean. I am thinking this might be a fuel pump problem, but I would like to get some input..
ZJ
07-06-2003 04:48:01
 Re: Bobcat 743B Fuel Problem? in reply to Stephen Shepherd, 07-05-2003 17:03:10
after it dies does the fuel primer bulb go flat? We hade a 763 in a transfer station operation that did the same thing. Inside the fuel tank there is a small strainer and a check ball/valve at the end of the line. It was really plugged up with alot of crud. unplugged it and problem solved. Kinda a pain to get at though..
Stephen Shepherd
07-07-2003 11:36:36
 Re: Re: Bobcat 743B Fuel Problem? in reply to ZJ, 07-06-2003 04:48:01
The primer ball does not go completly flat but it does become soft. I will pull the tank and check out the strainer. etc.. Thanks for the suggestion..
geok
07-05-2003 19:56:03
Had a Kubota diesel that would run up to 15 minutes then die.
Found a pin hole in the fuel line from the tank.
Stephen Shepherd
07-07-2003 11:37:33
 Re: Re: Bobcat 743B Fuel Problem? in reply to geok, 07-05-2003 19:56:03
Thanks I will check that out..
