Found a governor in my junk
Dan
07-06-2003 21:27:21
Is there a way to tell what its from or what it will fit or should I just hang it on the wall in the shop. Any ideas?
Frank M.
07-07-2003 18:04:34
 Re: Found a governor in my junk in reply to Dan, 07-06-2003 21:27:21
Danged politican have their hands in everything. Can't even leave a man's junkpile alone.
Dan
07-07-2003 18:46:39
 Re: Re: Found a governor in my junk in reply to Frank M., 07-07-2003 18:04:34
If it would have been a governing politicion I would have not hung it on a wall.
VaTom
07-07-2003 04:46:59
No, but if you'll send it to me I'll see if it fits the Ford 300 I just installed on my crane.:)
markct
07-07-2003 19:56:35
 Re: Re: Found a governor in my junk in reply to VaTom, 07-07-2003 04:46:59
yea the 300 ford sixs sure are a great motor, i got a caterpillar road grader that i repowered with one a few years ago, there is a pic of it under tractor photos on this site. i gota set up some sorta governer on it at some point too, i just been fast with the throttle so far, but a governor would be nice
VaTom
07-08-2003 04:13:28
 Re: Re: Re: Found a governor in my junk in reply to markct, 07-07-2003 19:56:35
Hi Mark,
I figured I could get by with a throttle cable hooked up. The link below is to Surplus Center. I remember their catalog offering left, center, and right mounts at one time. Not too sure what this one fits. If you figure it out, please let me know.
Dan
07-07-2003 06:31:41
Is that the Ford 300CID? VaTom.
VaTom
07-07-2003 10:30:19
 Re: Re: Re: Found a governor in my junk in reply to Dan, 07-07-2003 06:31:41
Hi Dan,
I hope that's right. Inline 6 that was used in a lot of pickups. Turned out to have a long stroke very close to the one that blew up-unreplaceable. Interesting getting the old flywheel, starting motor, and radiator to line up. All it does is run a large hydraulic pump. I'm not certain I need a governor, but the old engine had one.
VaTom
07-07-2003 10:33:41
 Re: Re: Re: Re: Found a governor in my junk in reply to VaTom, 07-07-2003 10:30:19
Crane is a 50 yr old Linkbelt.
Dan
07-07-2003 18:50:44
 Re: Re: Re: Re: Re: Found a governor in my junk in reply to VaTom, 07-07-2003 10:33:41
I have an in-line 6, 300CID in a '81 F150,very strong bottom end, maybe I could retro fit the thing.
VaTom
07-07-2003 19:34:35
 Re: Re: Re: Re: Re: Re: Found a governor in my jun in reply to Dan, 07-07-2003 18:50:44
That'd be great. Ummmm, you were offering me your engine as a back-up weren't you?
sod
07-08-2003 08:29:09
 Re: Re: Re: Re: Re: Re: Re: Found a governor in my in reply to VaTom, 07-07-2003 19:34:35
You won't need a backup for that engine. Ford 300's are the best motor that ever was built.
good luck
sod
