Int'l 2400 diesel fuel filter problem
Dan
07-09-2003 06:19:53
I have an International 2400 diesel tractor. I've changed both fuel filters and it runs but has no power. Can anyone help me with this problem?
Thanks,
Dan
Greg(Mo)
07-09-2003 18:56:41
 Re: Int'l 2400 diesel fuel filter problem in reply to Dan, 07-09-2003 06:19:53
Could use a little more info...did the tractor run ok before the filters were changed, or were you trying to correct an existing problem? Air filter ok? Does it smoke alot?
dan
07-09-2003 19:08:06
 Re: Re: Int'l 2400 diesel fuel filter problem in reply to Greg(Mo), 07-09-2003 18:56:41
i changed the filters because it was running bad, like it was running out of fuel. so i changed filters and have opened the vents on both filters and got fuel to come out, then the manual said to vent by pump but fuel never comes out. if i start it then fuel bubbles when it comes out. not sure what i am doing wrong
