Re: Need answer about operating a loader
Jim in Michigan
07-10-2003 06:13:21
should have hydraulic fuid in it, but you can use SAE 30 weight NON DETERGENT oil,,,do not use regular oil as it will foam ....use non detergent...Jim
Don LC
07-10-2003 07:07:16
 Re: Re: Need answer about operating a loader in reply to Jim in Michigan , 07-10-2003 06:13:21
Use non detergent motor oil, it will produce more pressure than hyd. oil....generally recomended for the older tractors....you will need a little more oil than it takes to fill the system when fully extended..... Tractor Supply Store has it in 5 gal. buckets..... good luck..
