Cat D2 starter clutch and pinion
Jim
07-14-2003 20:45:44
Can someone tell me how to pull the started pinion and cluth housing off of a Cat D2 4U series without removing the fuel pump? I have the unit loose but can't remove it.
Richard
07-15-2003 20:42:13
 Re: Cat D2 starter clutch and pinion in reply to Jim, 07-14-2003 20:45:44
take off the rear cover from the pump only & you will be able to remove the clutch & pinion. This is what I did on a D2 3J.
